Спасибо большое.
Я правельно понил он до 2.5 бар.
Parameter min type max
Feature Integrated temperature
sensor
Pressure range kPa (?...-) 50 350
Operating temperature § °C -40 +130
Supply voltage (1 min) u V 4,5 5 5,5
Current input at u = 5 V K mA 6 9 12,5
Load current at output © mA -1 0,5
Load resistance to u or ground ? kO 5 680
Load resistance to u or ground « kO 10 100
Response time ® ms 1
Voltage limitation at u = 5 V - lower limit V 0,25 0,3 0,35
Voltage limitation at u = 5 V - upper limit V 4,75 4,8 4,85
Limit data
Supply voltage ? V 16
Storage temperature °C -40 +130
Temperature sensors
Measuring range ? °C -40 +130
Measurement current mA 1 1)
Rated resistance at +20 °C kO 2,5 + 5 %
Temperature/time constant ? s 10 2)
Accessories are not included in the scope of delivery of the sensor and are therefore to be ordered separately as required.
