SIEMENS DEKA 870
Белгород
Исправные
Без
Тк
Сименс дека 870 4шт
Стояли у меня на турботазу, брал новыми. Работали без нареканий. Не проливал.
9тыс без торга
В продаже. А что сименс дека бывают не оригинал? Честно не знал.
Фото не мое. Маркировка 110324 таже
Siemens Deka Mototron 875cc 110324 FI114992 Spridare
Genuine Siemens / Mototron DEKA IV ( DEKA 4 ) High Impedance Injectors
These injectors flow 80 lbs/hr at 43.5 PSI ( 3 BAR ) and even more at greater PSI! In addition, these units are high-impedance. Despite the high flow rate, they are linear and controllable at low pulse widths and have been used in ULEV applications! This allows you to use a larger injector than normally possible without hurting idle and low speed driveability. Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector.
These injectors are able to function at high fuel pressures and dont exhibit the high fuel pressure handling problems found with many other high flow high-impedance injectors. This makes these injectors very well suited to turbocharged and supercharged applications that see high fuel system pressures.
This newly released injector from Siemens is based on the same design as the popular FI114961 60 lb/hr DEKA IV ( DEKA 4 ) injector.
Features:
Genuine, reliable Siemens Injectors
Excellent response characteristics
Robust Design
High Impedance
Low Impedance performance characteristics with High Impedance Compatibility
Specifications:
Static Flow Rate: 80lb/hr = 875 cc/min
Dynamic Flow Rate : 18.6 mg/pulse 2.5ms PW, 20 ms Period
Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers)
Connector: Minitimer
Series: DEKA 4 ( DEKA IV )
O-Ring Type: Viton
Cross References:
Siemens FI114992
Siemens 110324
Lagervara - omgående leverans!
Antoxa68
Обмен на 630 деку с доплатой не интересен?
VadimK, пиши в личку свои координаты.
Кулек, пайпы и выхлоп в резерве
