Интеркуллер вода/воздух Frozenboost Type 14
wooldoor
Отличное
До ТК
Продам жидкостный интеркуллер Frozenboost Type14.
Размер 300х300х120мм, ядро 270х160х120
Воздух вход/выход 3 дюйма, вода 1/2 дюйма
Угловые фитинги под шланг, где-то были и прямые
Мало б/у, внутри все сухо, проблем не было.
Описание с официального сайта:
100% Lightweight aluminum, No Epoxy Used In Core
Fin pitch is 21 fins/inch - 12.5 air side and 8.5 water side.
Recommended for up to 700 CFM / 600 HP
Pressure Drop: Less than 0.1 PSI. This is not a typo! Liquid/Air Intercoolers have incredibly low pressure drop.
Air Inlet/Outlet: 3.0"
Water Inlet/Outlet: 1/2" NPT
Maximum water/air pressure: 70 PSI
Core Size: 10.5"x6"x4.5" (Endtanks add to length)
The inlet and outlet on this intercooler are located at a 90 degree angle for cramped installations.
Note: The water inlet and outlet on most water/air intercoolers are BPT threads. BPT fittings are difficult to find in the United States, so ours all come with NPT threads.
