турба 3071 гтр
KMS
Белгород
подскажите по турбе 3071 в чем отличие??
turbo PN 700382-3 CHRA PN 700177-3 trim 84 A\R 0.64 inlet dia 2.75"
turbo PN 700382-20 CHRA PN 700177-4 trim 90 A\R 0.86 inlet dia 4.00"
не могу разобраться с номерами какую заказывать:?:http://www.turbobygarrett.com/turbobygarrett/turbocharger
ArtMan
Курск
Различие только в диаметре входа в холодную часть ( 2,75 и 4 дюйма соответственно) и А\Р горячки 0.64 и 0.86 ....
по колёсам одинаковые абсолютно.
KMS
Белгород
ясно,а горячки под встроенный гейт обе???раздуваться одинаково будут??да тоже интересно вход почему разный??
sharky
на что влияет большой вход??
What happens when you upgrade to a larger inducer while retaining the same exducer? The most notable change is more airflow capability; since the turbo is taking a bigger "bite" of air in every revolution, it can obviously "spit out" more air as well. Gee, more airflow aounds great... so why not go to the biggest inducer you can find? Because that creates two main problems, one much more important than the other. The smaller problem--really it's just a nuisance--is the turbo will now have a little more lag during spoolup (because the bigger wheel weighs more, plus it has to do more work with each revolution, etc). While this extra lag might not be noticed on a dyno--all the bystanders will be oohing and ahhing at the huge top-end horsepower such a turbo would produce--it would make for dissatisfaction in your day-to-day drive and could even cause you to lose a drag race to a car with less peak horsepower but more area "under the curve" due to his turbo that spools sooner. The real trouble with a large inducer increase but no exducer increase, though, is it makes the turbo much more likely to surge. Surge is the situation when the compressor "spits out" more air than the engine can swallow, which causes a backup of air at the intake and it actually creates reverse-flowing pressure waves that can be very damaging to the turbo. You want to avoid surge at all costs.
dpc82
давно бы так,теперь всем всё стало ясно как белый день
не читал написанное выше, но...
вот ссылка
http://www.turbobygarrett.com/turbobygarrett/surge_line
там визуально показано для чего это нужно и показано на турбокарте что дает.
если впуск большого диаметра и под ним видны перепускные антипомпажные отверстия - улитка может дуть раньше без помпажа чем обычная.
vassaby
Тут вроде же описан случай когда увеличен не только диаметр входа но и само колесо.
ArtMan
Курск
да обе под встроенный ... раздуваться пораньше будет на 0.64
у меня ТБО 2876 , горячка 0,64 ( но на втулке улитка) в + на 3000 об. на 1,5 моторе
у тебя на шарике будет раньше дуться чутка. вход у меня 4" ....
Пы.Сы. стандартную калитку гейта у себя закрыл наглухо - сделал коллектор под выносной гейт 38 ... гдето была информация , что сток калитки не хватает и уля передувает .
это встречается на китайских турбинах, просто надо дырку под калитку чуть больше расверлить(сделать так называемый тюнинг:) )
ArtMan
Курск
serjj, да инфа как раз за оригинал была... про китай итак ясно - у меня дыра под калиткой размером чуть более монеты 1 рублёвой ,
на т3т04е тоже самое ( передувала) - товарищ там раздрачивал шарошкой .
на ккр480 (твинскрол) тоже передувает жёстко -коллектор сейчас переделывается под выносной гейт
KMS
Белгород
У меня сейчас 2.75" 3071 3000 уже 0.2)))просто еще один мотор собираем турба едет а только по номеру посмотрели а там вход 4.00"а хотели 2.75"ну ни чего будем и на такой гонять)))
KMS
Белгород
K&N прям на улитку но говорят что может поплавиться,ну будем делать как нибудь,у дена ХМГ слеланна из отводов)))
у меня проспорт прям на улитку был одет. сжопилась резинка быстро.
КН кто на улитке юзал? у хакера точно видел одет прямо на улитку . . .
