После установки рессивера снизился цикловой расход воздуха.
tehno-lada
Тула,Косая гора
Мне кажется, что твоей голове до функционала довольно дорогого программного пакета, в котором моделируют газотурбинные двигатели, далековато.
Так вот этот пакет говорит нам следующее
По сравнению с квадратом
I laugh when I see **** like this. Guys that use "pretty pictures" to convince others of their design. In the real engineering world people would laugh at you. Let face it you know nothing about fluid dynamics and how a computer iterates the data to find a fluid path solution. Solidworks has the worst iteration solver and grid generator there is. It is only used for quick visuals. Quick visuals are not the right place for an intake manifold.
CFD will only spit out crap if you put crap in it. You need to set up your boundary conditions right, before you assume the sides are getting less air. They are getting less air due to the way you set up your boundary conditions up. You probably told it that the throttle body is the entrance point at XXX pressure or flow rate, and the runners were all basic outlets. Try a timed opening of each runner using the equation formula built into the software. Find the time sequence of the intake valve opening and place the formula for each runner opening by right clicking on each outlet. This will give you better visuals plus it lets you monitor flow between the runners.
Things like shock waves and reverse flow within the chamber make things complicated to calculate by any CFD to date. Even when using military CFD it is not possible to calculate it right due to the errors in the iteration the software will spit out.
The sides should see more flow. The slower moving air over the sides creates a higher static pressure. This will cause more fluid flow down those outer runners, as the pressure difference is the greatest there.
The best place for a throttle body is in the middle of the plenum. It has been tested many times over the last century. A smoother transition between the throttle body and plenum is needed so the separation (swirls) is more consistent. Throttle body facing down will help with shock wave distribution as it bounces off the plenum wall, so you got the right idea there.;)
Kompressor
Для любителей 46мм дросселя на атмо моторе.
Сегодня еще раз сделал выводы по поводу дросселя.
Приехал дружбан,у него за год поломались 4 дросселя 54.56 ,52мм.Суть такова что обороты начинают виснуть,так как качество исполнения дросселей гомно, решели перейти на ино дроссель,но подходяшего не нашли,купили с волги 60мм. Но перед тем как сделать это,сняли логи. на 56мм Цикловой 490 МРВ 345
После того как все поставили дроссель,сделали замеры Цикловой 514 МРВ 378,изменился звук впуска. Едет бодрее по словам хозяина после 5000 об.
m54
Kompressor, в ущерб планости хода на низах.
В моём случае я пробовал 54, 52 и остановился на 50. МРВ не менялся, зато эффект ненужного дросселя достигался уже при 65% на 54ом и при 75% на 52ом.
ant99
Новосибирск
Ну так какой ресивер купить на 1,7 низ под валы аналог сти-3, чтобы ездить 1500-7500? Бюджет 25000 рублей.
И после этого ты ноешь что тебе на 92 ездить приходится вместо 98 т.к. дорого и ты нищеброд?) Завязывай употр****ть:roll:
ant99
Новосибирск
cerber1, я покупаю только новое... Б/у брать это ... Неиззвестно что там с ним вытворяли до тебя десятки хозяев.
Ага немецкие фильмы с рессивером снимают)))
Проверять насколько выросло/уменьшилось наполнение и массовый расход воздуха надо так:
1. Снимаем логи на машине ДО замены дросселя, с контролем реального состава смеси, и убеждаемся что реальный состав смеси соответствует заданному в прошивке.
2. Меняем дроссель, ОТКАТЫВАЕМ программу, чтобы опять же смеси точно соответствовали заданным.
3. Снимаем логи и сравниваем, делаем выводы.
Контроль смеси был ДО и ПОСЛЕ?
m54
Вот именно.
Я сравнивал езду в режиме онлайн прошивки на каждом из дросселей.
А не прошился на 54ом и потом уменьшал.
Kompressor
Конечно шдк был вручен, до была смесь 11.8-12.2, после стала 12.4-12.8, это на расходомере.
odolen
У меня на сток дросселе 450кг воздуха и на 54м столько же...что я делаю не так? :-(
m54
У меня щас 430кг воздуха на объёмнике и мне хватает.
Непонимаю смысла гнаться за воздухом, если он свыше 7000об будет. Вы чо долго едите в этой зоне оборотов?
Ascari
Волгодонск, РО
наркоманы вы. у нас брагин тоже любитель 60 дросселя. всем подряд тулит. из доработок валы выпуск и рес, и обязательно на 60 дросселе. кудаж без него ога. побольше пиши на всех ресурсах то то у нормальных людей работы прибавится
И куда ты там долго поедешь на максимальной мощности?
По твоим легендам у вас ни дорог нет ни бензина.
m54
Serg_x, я езжу на оборотах 2200-3600 в стационарном режиме если. И обгонять шляпа, колёса в букс срываются оченб нехило. Резина липучка сношенная, а дороги в глине и грязи с лужами ещё к тому же.
При большой турбине на городской пулялке все за ранним спулом гонятся а есть он не у всех ))) У какого мотора будет спул турбины раньше, у того, что имеет дроссель 46 или 56 ? Какое отношение к " тяге с низов " имеет размер ДЗ? Какой УОЗ и МРВ будет у 46ДЗ и 60% ? А какой будет УОЗ и МРВ у 56ДЗ при 30% ? Или вот так; какой будет УОЗ ,при МРВ 300кг с 46ДЗ и с 56ДЗ ?
Ascari
Волгодонск, РО
При большой турбине на городской пулялке все за ранним спулом гонятся а есть он не у всех ))) У какого мотора будет спул турбины раньше, у того, что имеет дроссель 46 или 56 ? Какое отношение к " тяге с низов " имеет размер ДЗ?\
к тяге с низов - никакого. к удобству дросселирования и дрочильне на большой дыре - прямое
Ascari
Волгодонск, РО
Я пишу по факту что вижу и какие изменения происходят ,я не совневаюсь в Брагине, и то что он делает, значит так надо.
"поздравляю тебя шарик, ты балбес" (с) Простоквашино
секрет открою, раньший спул будет у кого больше мощности внизу, и соответственно больший выхлоп.
а на эти влияет объем и валы(+гбц)
зачем изобретать непонятное порно?
